Hello all,
I've been having some issues with my tachometer since I bought the boat. It's a Yanmar 2GM20F with about 350 hours; there is a tachometer sender in the bell housing- Not off the alternator.
For the first three days we owned the boat, the tach worked just fine; Then, it quit working altogether (although the hour-meter still works just fine). Wiggle wires, poke around a little, re-seat connections... and now the tach SORTA works. WHEN it feels like working, it reads about half what I estimate the actual RPM to be. (At idle, it displays about 400. At cruising speed, it shows about 1100 for a few seconds... and then quits working.)
SO, I decided today was a good day to try a few tests.
First, I used my ohm meter to verify that the sensor wire had good connectivity- No obvious issues there, even when wiggling connectors.
Next, bypass the entire sensor wire with a jumper wire straight from the sensor to the back of the tach. No change in readings; still showing idle at 400 and approximate 'cruise' at 1100; thus, I've eliminated the 'sensor' wire as a possibility. Only other wires going to tach are Power and Ground, and they both have good connectivity.
Unfortunately, my multimeter won't do KHz (Cycles), so I couldn't try to determine if the sensor is working...
Does anyone have any ideas what I should try next? Does this seem like a bad sensor, or a bad display?
Thanks in advance,
--Jon
Thanks in advance,
--Jon
