Ron Brassord
One by one, I have been fixing the problems in my recently acquired 1988 C30 caused by neglect. I have been very happy with the boat generally, and the problems have mostly resolved. Since buying the boat in July, the tack has not functioned. The hour meter does work.I got the U 25 xp cleaned up and running great. The alternator did not have a tack wire on it, and I found the end of the original tack wire laying in the bilge. The previous owner evidently installed an automotive alternator without the wire. I bought a new higher amp unit, and had the wire installed. I tested the red wire to make sure it was the coming from the back of the tack, and it is. However, I get no response running the engine, and the rpm needle is still non functioning. When I turn on the key, the rpm needle does jump to 3000 rpms, and is peged there until I turn off the key, and it returns to zero. Question, do I go for a new tack? Any other test I can run? Is this tack repairable? I looked at the Torreson parts list, and it shows a replacement cost of over $350? Marine stores have tacks for under $100? Someone suggested a "Mighty Mite" which takes a reading off an injector feed line at $70? I'd like to stay original if possible and use the same hole and wiring, but not at $350. Anyone had and resolved this problem? Good sailing Ron B
