david lewis
Several forum participants recommend that I install a tachometer for my Universal 25M diesel. I concur with their recommendation but I wonder what is involved. All my past experience is with outboard auxiliaries on smaller sailboats. There is no place for a tach on my instrument panel. Should I replace the whole panel and if so who is a source for this item?Also on a gas engine a tach is easy as you can inductively pick up the voltage from the spark plug firing. What is used on a diesel? I assume a magnet mounted on the engine shaft and a magnetic transducer?Any advice will be most welcome.Regardsdave
