G
Guest
The pair of short legs which support the salon table in the "down" position as used for sleeping were shipped 1 5/8" too long. The result was a berth in the salon with two heights...very uncomfortable? Inquiries with Beneteau suggested that since these legs are OEM from another supplier, the exact length is not available!As a solution, I had a local welder cut 1 5/8" out of the center of the legs (not the end because there is a taper at each end) and reweld. Result, for under $30.00 is a good fit and perfect height. Only negative is the appearance of the legs with a weld in the middle. Since they are concealed under the berth, not a big problem.I would be interested to know if other owners have had similar "height" problem and if they were able to get different heights from Beneteau?ThanksSpencer
