Table is milky looking due to sun
Bob
I have a Hunter 320 2001 and my table below has become milky looking. Is there anything to use to rub it out to make it look new again? Bob
Jim
May 21, 2007
775
Catalina 36 MK II NJ
Boy that is good for a joke!
You should have keep it covered.
Jul 24, 2006
628
Legnos, Starwind, Regal Mystic 30 cutter, 22 trailer sailor, bow rider NEW PORT RICHEY, FL
milky
i used to be a painting contractor. I would use sanding sealer under the varnish, or poly urethane. I did an exterior door once with this combo(the sanding sealer would dry quick so i could sand and top coat in one day). the door turned cloudy in a short amount of time. I had to stip the door and refinish with just poly. Don't know if yours is varnished but if it is they may have used sanding sealer or something like it. I feel your pain the cloudy finish is ugly!
