Cooler yes, dirty for sure
Rick, I spent 17 years with an engine bearing manufacturer. You are right that the oil does play an important role in cooling the engine where it gets hot first, but don't forget that a diesel engine runs properly when it reaches its normal operating temperature. However, the real important factor here as Gordon puts it is the fact that diesel engine oil gets dirty and contaminated because of the blow-by that takes place when the engine is running. That is why we must change oil frequently because our engines generally do not get dirty on account of dirty air. So, if we must change oil frequently to make sure that its clean, what is the point of using a more expensive and longer lasting oil that you will need to replace before it has reached its so-called life span. If the oil gets dirty it needs to be replaced, whether it has broken its molecular qualities down or not. That I believe is the real point. Hope you enjoy your Thanksgiving week-end ! BTW, do you keep your boat at Point Cadet, BYC, or Small Craft Harbor ?
