switch water temp alarm
Sep 6, 2018
22
catalina 310 285 waikawa NZ
hi there if you google yanmar 3gm water temperature switch you should find it i am only guessing that the thread into the block is the same size alarm threshold should be similar cheers nigel
May 20, 2016
3,015
Be very sure of the threads. The NPT and Metric parts are close enough to start, but won’t cleanly tighten up.
Nov 16, 2012
1,055
Good point. Pretty sure it’s 1/8” NPT, because the petcock on the housing is, and I did find one parts manual that showed it being used with a 1/8-1/4” adapter.
However, I couldn’t find a temp switch with a ring terminal, only 1/4” spade connection. That might be more secure than the original slide on design, but not ideal.
