SWINOMISH CHANNEL BNSF SWING BRIIDGE to be closed in APRIL
Plan your cruising accordingly.
Swinomish Channel Swing Bridge Closed for Two Days - Updated Info. 12:15 pm 4/1/22
The U.S. Coast Guard had announced in the Notice to Mariners that the Railroad Bridge at the north end of the Swinomish Channel would be closed daily for two weeks in April. BNSF Railway has corrected the closure dates, stating that the railroad bridge over the Swinomish Channel will be closed for two days only -
April 12 and again on April 26 from 9 a.m. to 3 p.m.
This closure is to accommodate mechanical repairs to the swing span. During the closure times, mariners can use the alternate route via the southern Swinomish Channel through Skagit Bay.
Dec 25, 2000
5,948
Thanks, John, for that news update. Weather permitting, I'm planning on a one week cruise around the islands 4/11 - 4/15.
I'd love to join you, but I am reinstalling injectors on my Perkins. Have to be back in Salem before the 15th to celebrate my wife's birthday.
Looks like the 12th is the date that would cause you to use Deception rather than the Ditch to get to the Islands.
Thanks Terry.
Some days it is all Love and Kisses... Some days it's a maelstrom...
Kind of like sailing....
Maybe... Dinner on the coast with a view of the Paciifc. Two birds... One stone.:biggrin:
Though the Crystal Ball is still fuzzy, I saw this message from Rufus in his Monday prognostication. Rain Gear and a change of clothes plus your fleece may be needed in the Islands.
Split outlook for Mon-Wed Apr 11-13. One scenario - another weak, but warmer disturbance may clip the PNW late Tue night into Wed; scattered showers / cloudiness likely, with mild, dry conditions to end the week; the other scenario calls for a cold storm to form and push onshore later on Monday, setting up a breezy and chilly Tue/Wed, with continued damp wx through Tax Day. Coin flip accuracy.
Easter Weekend. Well, the threat of more cold conditions this Easter has been trending off the charts; so, maybe it was an April Fool’s joke after all? Seriously, a relatively dry & fairly mild weekend is what model solutions present of late. However, best to plan on some rainfall or showers for now, as that remains the prevailing solution. We’ll have time find consistency for what the weather will be like on Easter. Patience.
“People judge a leader less by how he or she is doing than by how they are doing."
-Rufus
Dec 25, 2000
5,948
Thanks for the prognostication, weather honcho. Hopefully, a reasonable weather situation for this coming week.
Here is Rufus's latest update. It suggests a lot of questions regarding weather. I know you have your boat equipped.
Friday April 8
Very out-of-the-norm weather ahead for the next week. Morning beverages should be hot. What’s up?
The wonderful BBQ Day (Thu Apr 7) has now passed. It will be awhile before that kind of day returns. A relatively dry, but quite cold air mass, is now moving into the PNW. Temperatures will drop rapidly behind the front. There will be precip falling throughout the weekend, most of which will fall as SNOW down to 500-1,000 ft by later tomorrow. The ground is warm, so lingering snow will not be likely. Don’t be surprised to see a mix of rain/snow at your location. It is extremely rare to have this type of cold pattern in April. For portions of western OR, the latest measurable snow (0.1 inch) for Portland was March 25, 1965; Eugene April 11, 1911 (Weagle, Nat’l Wx Service). A ‘measurable’ amount of The White west side is less than 30% likely - per some model output - but there is an outside chance within the next 72 hrs. Sip on.
Well below normal temperatures this weekend. A weak system on Sat may tease some rain/snow mixed at the surface, but the big question will be the track of a second potential Low moving onshore late Sunday/early Monday. This storm may not only be cold enough for some snow/rain at the surface, but also become a relatively strong WIND PRODUCER, depending on which wx model solution verifies. If the Low tracks onshore north of OR, wind will be strong across western OR; if it tracks farther south, less wind, but colder air impact for chance of snow showers down to 500 ft, or lower at times. Patrons living in the foothills, coast range area or along the slopes of the Cascades above 500-1,000 ft may receive a few inches of snow.
Next week: the unseasonable cold pattern holds, with variable low snow levels and showers on through Wed. If the sky clears in your location, FROST will be a concern as early development on fruit crops will be quite vulnerable, esp Wed and Thu mornings. Let’s hope there’s cloud cover. (The frost we forecast several days ago for the Sacramento Valley area, CA did reportedly have a negative impact on almonds, tree fruits and, in some cases, specific grape varieties.)
Unfortunately, Good Friday next week is also Tax Day in the US, with the chance for another cold front from the NW to arrive. We’ll see. Models do suggest that it may warm up and dry out a bit for Easter Sunday. The week after Easter continues to chart as damp and unseasonably chilly.
Bottom line: below normal temperatures are charting for much of the next 2 weeks. Precipitation should trend as normal. The Cascades will have significant additions to the 2022 snowpack.
“Golf is much like taxes - you drive hard to get to the green and then wind up in the hole."
-Rufus
Dec 25, 2000
5,948
Sheesh! What a wet blanket. Well, at least no temps in the low twenties and four inches of snow thrown about that we had back in February.
