Swing Keel
Al1909
Mar 6, 2005
1
- - Warwick RI
I purchased a Cat 25 last summer...It has a swing keel. Does anyone know how much my boat drafts? When should I change the cable for it? Finally, can I eliminate that humming noise when we are sailing? Is it the cable which is causing this?
Humm
Al It does hum, but you can work on it with adjusting tension on the cable. You need to go to: www.catalina25-250.org. You'll find the answers there. Stu
Jun 4, 2004
94
Catalina 22 Cape Cod
Cat 25 Swing Keel
The Cat 25 draws about 5 ft, maybe 5'6" max. Change the cable when it starts to show signs of wear. The cable hums while sailing if there is still tension on it. Just lower the keel a little bit more and it should go away. Regards, Ted
Jun 22, 2004
1
C25 Info
Al, Like Stu, I encourage you to go to the Catalina 25/250 National Association. There you'll find all the information you're seeking as well as a friendly and knowledgeable Sailor's forum. Click on the related link to take you there.
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
C25
C25 SK draws 2'8" board up and 5' board down and weighs 1,500 pounds. As the others have stated, check out the C25 forum.
Steve
Cable "hum"
Actually, I like the cable hum. It's sort of like the turbo whine in a sports car....confirmation that I'm going making good time. Steve
L
Leprechaun
Catalina Assn.
Congratualtions on your New Boat! We have owned a Catalina 22 with a swing keel-yes that hummed also! and now own the Catalina 25 swing Keel- I would encourage you to join the Catalina 25 sailing association .. it is well worth the money..you can find the information by going to www.catalina25-250.org Good Sailing! Alan 1987 Catalina 25 TR/SK #5612 "Leprechaun"
