Swing keel question
1
- - Black Rock Harbor
Does the swing keel on the 23 "swing" all the way up into the keel so that it is totally hidden or does it hang down some. I can't seem to get mine to go up farther then where about 4 inches hang out the bottom. Thanks! Ryan
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Keel centerboard
Your centerboard should go all the way into the keel on your 23. If your 23 was built before 1974, the keel and centerboard is made of cast iron, otherwise if you have a later model 23 the keel is lead and the centerboard is made of Fiberglass. The O'Days 23s with cast iron keels had problems, so I've been told. At any rate, if the centerboard isn't going all the way up, there must be something preventing it from doing so.
Sep 8, 2006
116
Hunter 23 Camp Lejeune, NC
No
No it doesnt go all the way up dont break it trying, if any doubt call hunter!
