Swing Keel question(s)
312
hunter 23 Lake Hefner
I recently bought a 1985 23. There are 2 lines that go down the cockpit drain, through a tube to the keel where it attaches to the swing keel. When I pull one of the lines from the cockpit it barely moves and I can here the swing keel thump on the bottom of the hull. When I pull on the other... nothing - it doesn't budge.
Sooo, I swam under the boat. The keel moves freely and I can deploy it to the down position manually without effort. It has some side/side play but not scary. The 2 lines that are attached to the keel are easily pulled down the cockpit drain from the keel attachment area :doh:. When the keel is deployed, one of the lines move about 8 inches. When cleated the keel is deployed with a maximum amount of tension, but fairly easily deflects back about 10-15 degrees then holds.
Sooo... my questions are: Is the purpose of one line to pull deploy the keel and the other to keep it in the up position? Why would the keel not deploy in the first place?
TIA.
Aug 22, 2009
3
2 23 Lake George, NY
TIA.
Did you find an answer to this? I just bought an 85 Hunter 23 and haven't put her in the water yet, but your estimation of the lines leading to the keel is what I surmised myself.
Likes: 1 person
Jun 28, 2009
312
Unfortunately no reponse. Where's Crazy Dave nowdays anyway? I love my boat btw. It sails great. I don't have a windex but it seems to point well and is dry as a bone inside. The only problem I have had was with the stupid OB motor, but that is not a problem with the boat :)
Let me know how you do with your 23.
