Swing Keel Problem 26'
H
Harry Plaganis
We where in heavey chop at dock and heard noise near the table , lookes like something is loose somewhere down below to make the table move a little.Any ideas.
Dave Condon
look
Suggest that you remove the plates at the base of the compression post and see if the bolt holding the centerboard housing is tight. If it is, then there will be some play in the center board where it comes up. This is a start Crazy Dave
