E
Eric Schmidt
Question...The line, block and cable assembly is there to hold the keel in the upward position. Correct? What is holding the keel in the down position? Just the weight? Is that keel moving backward when the boat start to get some speed and the water push on that keel? What is your experience? What do you think? Should something be done to hold that keel down?Thanks
