Just returned from a short day cruise on Lake Erie. While on reach (10 - 20 MPH wind with 2' to 3' following sea) the swing keel was making an occasional thud sound. Is this common with swing keel boats? No noise when sailing into the wind.
My O'Day 222 does that occasionally when I'm sailing down wind in choppy seas. If the seas are gentle, I'll raise the board all the way up when I'm on a run down wind.Just returned from a short day cruise on Lake Erie. While on reach (10 - 20 MPH wind with 2' to 3' following sea) the swing keel was making an occasional thud sound. Is this common with swing keel boats? No noise when sailing into the wind.
John,Joe, Thanks for the input... I'll inspect on Sunday...
I did receive a new Pendant line and shackle from D&R Wednesday. Is there an easy way to replace this line? My trailer has the horizontal rollers under the keel that stops any chance of lowering the center board! Will I have to employ a sling, or can the change be accomplished in the H2O?
Regards, John
Is the boat still out of the water?Pulled boat out at Humbug Marina to applt decals ("Happy Dolphin") and replace Pendant for centerboard. Decal appl. went well; but the pendant line was attached through a hole in the lower leading edge of the keel through to a lateral hole (1.25" Dia.) where a knot was applied and where the knot and hole was filled with an epoxy product and smoothed! Wondering is this a normal or original application? The pendant shakle width was not wide enough for the keel, plus the replacement line appeared larger than the one I'm replacing? I may talk to D&R on Monday or Tuesday...
