A number of people have done this. We did...Have an S model...
Just wondering if anyone has re-routed the swing-keel lift rope to somehow go to the cockpit so you can make adjustments without having to go below?
I'm curious, how did they run the rope between the liner and the top?]
I ran a wire through the hole in the cockpit bulkhead straight back to where the hole is drilled for the CB rope coming through the head wall. If you work through the opening above the sink, and remove the styrofoam, you make access for your hand and arm to reach up in there and pull the CB rope through and attach it to the wire with tape and then pull it through the hole in the cockpit. Just be sure when you drill that hole in the cockpit that you line it up with the open area between the bolts on the cam cleat mounted through the cabin top because you don't want that rope chafing on any bolt threads. By the way, the inside head wall where the CB rope goes has enough space to set up a 2 to 1 pulley system that makes that CB alot easier to raise.
Cool,I'm curious, how did they run the rope between the liner and the top?]
Thanks.
Hope these pictures help answer your questions. In the 1st photo, I had to pass the rope around my Finspray pump using a small cheek block. The pump base is fatter than the standard Mac pump. I mounted all my blocks on oak pads bolted through the head wall for extra strength. I gathered most of this info from other posters on this website and if you search the archives it may be of help.So how, or where, did you mount the turning block that the rope has to go through to turn toward the cockpit? Is it still on the head wall? On the inside, which space does the rope go through?
Yes there is a pulley in there and it's called a thru-deck block. The block in the second picture where the rope exits verticallly into the head area is called an upright lead block and it's mounted out of sight under the fiberglass. The other where you pointed out in the last picture where the line makes a 90 degree turn to run between the liner and the boat's deck is the thru-deck block. I used 5/16" line and that's the max these little Harken blocks will take.Thanks BR...that last picture...the little black thing the rope goes through when it turns through the head wall...is it actually a pulley in there, or just a rope guide? Is there a pulley that mounts "thru deck" so-to-speak that would work there?
It also means drilling holes in the bottom of the laz. Creates a leak path into the cabin???That's another interesting thought...keep it low and routed below the aft berth... That way also, it's back by the tiller instead of on the front of the cockpit. Hmmm...
I thought about that. My plan is to fiberglass in a thin wall around the block and line. It wouldn't need to be too high. A section of PVC pipe sliced in half would make a good formIt also means drilling holes in the bottom of the laz. Creates a leak path into the cabin???
I think having the CB control right there by the tiller is cool though.
Jim
Kinda like the way Mac did the rudder tube?I thought about that. My plan is to fiberglass in a thin wall around the block and line. It wouldn't need to be too high. A section of PVC pipe sliced in half would make a good form
Hopefully you guys will document thisI thought about that. My plan is to fiberglass in a thin wall around the block and line. It wouldn't need to be too high. A section of PVC pipe sliced in half would make a good form
Well you know that Ruth and I share almost everything 50/50.....Sum, what does "50/50" on the pee containers mean? 50% margaritas ?![]()
Ruth got a laugh out of the......I mark my antifreeze jugs the same way. Couldn't pass up a chance for some humor.![]()
...part, but she also asked me if I had really shown people our pee containers50% margaritas
