Swing keel info needed
4
- Picnic Cat Philadelphia
Swing Keel info needed. I am new owner of 250 Water Ballast. With the boat on the hard, on jack stands, how much side to side play should there be in the board when it is down. Actually the board is down about half way and resting on a block of wood to keep tension off the cable. There doesn't seem to be much play but just a little. Any response would be appreciated by a newbie to this forum.
Dan
C25 - C250 National Association
HI Jeepster, there is a C25 - C250 Catalina National association. You can post your question over there and will get some answers also. Dan (I am assuming it is a Catalina) http://www.catalina-capri-25s.org/
