John
I am in the process of purchasing a 1981' 22'(in the water) the swing keel is lowered easily with a rope by hand (no winch)My question is this: is there a portion of the ballast in the form of a small keel below the hull that the swing keel comes out of or is the bottom smooth or "flat"? I am trying to rebuild a trailer to fit the bottom configuration and wondering if there is a "mini keel then I will need to take that into consideration. I can view a 1982 22' at a marina on a trailer, would an 81' have the same bottom as an 82'? Did Hunter perhaps have more than one keel/ballast configeration for the two years? Also the weight of this boat was listed as 3200 LBS is that correct? Thanks to who ever can contribute.
