You are getting good feedback
Howard: You are getting good feedback so far. I agree with the other replies. I don't believe that your keel is the whole way down as shown in your photo. (I hope you don't mind, but I attached a copy of your photo to my message after I lightened it. I had to lighten it to view it on my computer. I thought that this may help you get additional replies to your question). Anyhow, as Ted said, your keel should be about 5 feet below the waterline when it is fully dropped. Also, the bottom of it should be approximately parallel to the waterline when it is fully down, which yours certainly isn't as shown in the photo. I agree that your keel may be sitting on the board on the trailer, but I assume that you just did that to keep it from swinging while you were taking the photos. I do want to tell you that I have to unscrew my keel locking pin more in one position than in the other position. What I mean, is that it is a different number of turns to unlock the keel in the "keel up" position than in the "keel down" position. I recommend that you loosen the keel locking bolt almost until it falls out, or even take it out completely, and then try to lower the keel again. It is possible that you didn't have it loose enough, then when you lowered the keel it caught on the bolt. I hope this helps, Aldo
