Swaying Trailer
The previous postings are good suggestions I have found the MAC trailers to be difficult to load the boat far enought forward. If I am trailering long distance, I usually have to 'float' the boat 2 or 3 times to get it far enought forward, each time, I gain a couple of more inches forward. This is also dependant upon the ramp where you load it.I just got a new truck which sits higher than my old one and now I have some swaying at about 65 MPH. I just make an 800 mile trip and on the return, I worked the boat as far forward as possible and did not have the problem until my truck got below 1/2 tank of gas. With a full tank of gas, I hid 80 MPH without swaying. A little bit makes a lot of difference. I did not remove my motor as mentioned earlier. That is a good idea.My trailer has 2 horizonal "V" mounts which the boats sit on rather that the vertical bunk rails. I plan to build up the back mount so when I stick the trailer further in the water, the bost will be more level on the mounts simultaneously thereby easier to get the boat farther forward and should put more weight on the front of the trailer. I do not strap the bow real tight because it appears to pull up on the tongue when the boat bounces. I am still considering whether to strap the back of the boat to the trailer. I just can not imagine a 2500 pound boat moving out of the "V's" on the trailer. Good luck!
