Whats you favorite, product and process for swabbing the decks? I'm just looking to do a deep cleaning and maybe some protecting this spring before I put the canvas back on.
Thanks!
Thanks!
.... (snip).... I have also used a pressure washer ....
What kind of wax do you use for the deck and whats the application/removal process for the non skid surfaces?BEFORE waxing the topsides, I wear old clothes and shoes. I use a medium stiff brush with a solution of car wash soap (or your favorite) and about 5% bleach. Soak, wait a bit, and scrub. It cleans the mildew and mold nicely. I have also used a pressure washer holding off the deck to reduce the pressure on the surface with good results, but the bleach wash works a treat.
That is cool and makes sense. Sodium percarbonate is what you get when you mix baking soda and hydrogen peroxide. The peroxide will oxidize organic stains and the bibarb ( baking soda) will help with rust stains I think oxalate mixed with peroxide would work even betterI use Awesome Oxygen from Dollar Tree on my deck. It's a sodium percarbonate product, like Oxi-clean. It's relatively harmless, even to the fishes, and does a good job with a little brush scrubbing.
Do not wax your non-skid or your deck. Scrub 'em down. You can wax the salon top. You could wax your cockpit sides, toe rail, and gunwales.What kind of wax do you use for the deck and whats the application/removal process for the non skid surfaces?
I was wondering, thanks for clearifying.Do not wax your non-skid or your deck. Scrub 'em down. You can wax the salon top. You could wax your cockpit sides, toe rail, and gunwales.
For really stubborn mildew, dirt, stains, or scratches, 1200 grit wet sanding works great. The boat gets super clean. Do not sand your non-skid. You will remove the texture.
I have never applied wax to my walking deck area. I do was the cabin top and smooth fiberglass deck areas even though I sometimes walk across those areas.What kind of wax do you use for the deck and whats the application/removal process for the non skid surfaces?
