Hi All,
I am having problems with my brand new Suzuki DF-6.
It starts fine, it runs fine for about 20 min. It will run even longer if I keep it in high RPMs.
Once the motor is warm (usually after about 20 min) it would fail me when i go into lower RPMs.
It dies on me, and I cannot restart. Fuel is dripping out into the water.
If i take the spark out, it is black of soot, and its foot is wet.
That makes me think: the air to gas mix is too rich. Now, I am having trouble locating the adjuster. I found a tiny screw at the top which could potentially be it, but even if I bring it out 8 half turns, I don't see a change in the motor's behavior when idling.
Does anyone know:
* if I'm right suspecting the ratio as the cause for my problem
* if I am trying the right screw to adjust the mix?
Thank you!
Mario
Does anyone know:
Thank you!
Mario
