David Foster
Olivier's story excited a lot of comment, including several that a 27 foot boat is "too risky" for an ocean crossing.I see surviving at sea in two parts - seamanship, and boat handling when upright in the wind, and - boat survivability if it is rolled by a breaking wave.The first deals with seamanship, rigging set-up, strength and redundancy, reefing, storm sails, drogues, hatch/hull strength against blue water, ability to shed water, and protection/comfort of the crew. The only place length enters this equation is comfort. But the h27 has 19 percent overhangs (LOA/LWL-1) to offset its short length. Olivier's seamanship, North Sea experience, and willingness to take advice convince me he will be ready on the rest of these issues.Surviving a roll requires a hull design that will get you back upright quickly, a waterproof cabin (with an emphasis on latching down the companionway hatch-boards), proper stowage, and rig strength to keep the stick up underwater. Waterproofing, stowage, and rig strength/redundancy can be assured by modifications and have nothing to do with length. But the length is a key variable in stability of the hull design. A recent article in Yachting World rightly focused on the stability curve of the design. At what angle does the hull lose positive righting moment? (120 is good) What is the area under the curve where stability is negative and the hull will tend to stay inverted until another wave rolls it to a positive righting moment?I have not seen stability curve for the '75-'83 h27, but the hull shape (rounded shape of the decks and high cabin roof) does suggest good performance on this issue. We can look at the capsize screen numbers to get an idea of how length affects stability (in the abscence of stability curves.) The h27 has a capsize screen of 1.93 (less than 2.00 is considered suitable for ocean cruising.) I surveyed the modern Hunter offer (designated by 3 digits in the model list on this site.) The shortest hull in this category with a capsize screen below 2,00 is the 430 at 1.94. You have to go to the 450 to get a better number than the h27 at 1.89. Based on capsize screen, the Cherubini design of the h27 is equivalent to the modern 430 for seaworthiness in a roll.For our friends who are circling the glode, or cruising the South Pacific in modern hunters, I am _not_ saying that these boats are not blue water worthy. And I think the modern designs are excellent for the coastal cruising, and less than gale winds for which they are designed. But I am saying that a properly prepared and strengthened Cherubini h27 shows every promise of handling blue water as well as much longer modern boats. So it is design, not length that is the critical variable - as we know from the many successful roundings in 27 to 30 foot boats.A final word. A 40 foot boat presents significant issues in quickly handling the much more powerful sails and rig they carry - a major issue in the seamanship category.DavidLady Lillie'77 h27
