Surveyor says?...
Feb 6, 2013
437
Hunter 31 Deale, MD
Actually it was five years ago when we bought the boat that the surveyor pointed out that anchor hatch was soft and the core was probably wet. I put off the project because of other projects. Now in preparation for painting the deck this repair has to be done.
You can see the condensation on top of the hatch as a result of the wet core.
And the core exposed.
I guess this is end-cut or cross-cut balsa? I'll probably use marine grade plywood because the difference in weight for that small an area would be negligible (especially comparing dry plywood to wet balsa) ;-).
94
Hunter 31 Georgetown, MD
We had the same problem.
I used Azek from the big box hardware store cut in to strips and glued with West systems epoxy. Be careful not to flatten out the arch in the lid as I mistakenly had done. Then cover with cloth and thickened epoxy to radius the edges.
Very solid repair and it will never rot again.
