Survey: 135% Genoa or 150% Genoa?
K
Kevin
This is a quick survey. If you have a Hunter 23 with a Genoa (or two) send an email message to kjkeen@att.net and confirm whether you USE a 135% or a 150% (or both) genoa jib from your sail inventory. Results will be posted anonymously to this article. Thanks, Kevin.
Ray Bowles
Can a 130 to a 150% genny even be flown with
the spreaders in their current position on a B
K
Kevin
Spreaders and Genoas
Ray: With tracks for fairlead blocks and running the sheets outside the shrouds, 135% or 150% Genoas can be flown on a Hunter 23. - Kevin (Keen)
Steven Gautney
Does having the sheets outside affect pointing?
I have a 23.5. We have tried a 150% sail and still use it in lighter air.. .But my preference has been to stay with the original 110% because I believe I can point closer to the wind. We then use an asymetrical for reaching. I want to know if my theory on pointing is accurate . . .
