Surplus items
Oct 30, 2019
24
I am tired of looking at the following Vega items lying about my garage and therefore if nobody (in UK) is interested I intend to consign them to the dump this weekend so it's the last chance.
Bosch 35 amp alternator, believed to be serviceable, ex MD6A
Hella control box, starter solenoid seem to work OK but I suspect the voltage control side is u/s.
Sails (again), one main average condition but serviceable, one r/r Genoa which is reasonably good.
Any offer for above considered (plus delivery).
Regards to all.
Frank, ex owner V1775.
[Non-text portions of this message have been removed]
Dec 18, 2001
31
Found some more items!
Whale fresh water foot pump. It appears to pump OK but has a spare gasket set just in case!
A pair of prop blades for a Combi system. One has a couple of 1 cm diameter pits and two or three small holes at the blade tip. It would perhaps be acceptable to use for a season if you were in dire need of one blade. The other is in far better condition with shallow pitting towards the tip which has been filled. Note - the gear teeth on both blades are in good nick.
Gasket set (I assume for an MD6A - it came with Alkira). I don't know if it's complete but the head, exhaust manifold and some other gaskets are there together with some seals.
Anybody interested please contact me on frank@...
Regards
Frank.
