Hi All,
I've just purchased a Catalina 30 with a M25XP diesel. The motor has an uneven idle and the revs tend to surge( go up and then go down in a continuous cycle). It has the same issue at low revs but is less noticeable at higher revs say up to 2200. The motor has 1000 hours on it and has been well looked after. It has never stalled and doesn't seem to have any problem running at cruising speed. I'm wondering what might be happening here. I'm thinking there is no issue with fuel supply but maybe there's a dirty or partially blocked injector? Anyone experienced these symptoms?
Speaking of injectors I see new ones can be bought for around $70 each. Is this a cheaper or similar cost to getting the old ones serviced or rebuilt (assuming I removed them myself)?
Appreciate your thoughts..
Kevin
Kevin
