Tuyen
I have a couple of questions. If someone can help, I would appreciate it very much. My boat is a 1990 Hunter 30. Last Saturday I found my AC main breaker kept tripping. If I switched the AC main on with all other AC breakers off then the AC main would stay on. But as soon as I switch one of the other AC breakers such as outlets (I got 1 small fan plugged in), or battery charger, the AC main would tripped. I thought my AC main has gone bad. So I went to West Marine to look for replacement. But none was available. Then I found that my AC main breaker is a tripple pole type??? So I guess my first question is why tripple pole? It looks like I only have 120v circuits in my boat and the AC power cord I have has only 3 prongs. So was it tripple pole or was I mistaken? Then I started to disconnect the wires to remove the breaker in order to take it to the marine stores to find the replacement. Then I noticed something like an ic device connect diagonally across the main breaker. I didn't know what it was, but I just removed it, then connected the rest of the wires back just to see what happened. Then like a miracle, the breakers worked again. I could switched on the main, the outlets and the battery charger. And my boat is a great boat again. After that I went on the internet to research the ic device I removed. It looks like the ic device was a surge arrestor. And it may be obsolete, although I probably can still buy it. So I wonder if anyone else know what I am talking about and if I really need to replace that surge arrestor? After all, that little ic surge arrestor probably can't stop that much of a surge, and the only things that plugged into the AC circuits are the outlets, battery charger, and the hot water heater (which I normally leave it off). Thanks.
