Supply Source for 10 MM Polyester Yacht Braid
Jun 5, 2004
485
Hunter 44 Mystic, Ct
I believe that the in mast furling line on my H 44 and probably many of your boats was originally sized at 10MM. The original line has a yellow tracer. I had to replace this line after 8 years of use and the Selden website says the line can be replaced with 3/8 inch yacht braid which is "slightly" smaller than the 10 MM and feels a bit different. It also tends to slip in the mast furler when furling against any pressure. I tried going up to 7/16 yacht braid however this line is slightly larger than 10 MM and does not pass readily through the blocks at the base of the mast.
Does anyone have a source for (truly) 10 MM yacht braid? I suppose the good news is that with every attempt I'm getting better at making the end to end splice but I am also already into this project for over $100 trying the various line diameters.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
3/8 (.375) is only 1/32 (.031.25) smaller than 10 mm (.392) so it seems to me that 3/8 would be fine you may be used to the feel of 10 mm but it will not take long to get used to 3/8 and the strength difference is negligible by comparison .... over time the 3/8 will swell up some because of dirt build up...i work with dimensions all the time and would not worry about the diff un less you are building a clock
Jun 5, 2004
485
DOug
Thanks but that line is too short for my in mast furler which requires a minimum of 44 feet.
Jun 9, 2004
615
Catalina 385 Marquette. Mi
You are welcome Marc....someone will probably buy it. Not Vela!! Suggest either Catalina Yachts Store or Mauri.
Mar 26, 2011
3,750
Corsair F-24 MK I Deale, MD
There are also brand-to-brand variations. NE ropes 3/8 Stayset and Samson 3/8 XLS are significantly different. There are also finish differences. If it is critical, take a piece around to the local stores.
