Hi Steve & all.
My overheating problems are over (fingers crossed) thanks to Steve B &
all who gave advice.
The engine temp gauge barely reaches 40 centigrade now even on a long
run & temp of engine block measured with digital thermometer was less
than 70 centigrade.
I'm advised by friends that I should fit a thermostat (there is none
fitted at present) as running the engine cool means
1) higher fuel consumption (I dont really care)
2) more contaminants left in lube oil to cause corrosion etc (I do care
if true)
Should I fit a thermostat?
I found a UK supplier last year but lost it - Steve can you advise?
Thanks
John
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Albin Vega 1447 Breakaway
than 70 centigrade.
if true)
Thanks
John
