Look for Quality
Hi Jim,Not all lines are created equal. I use mostly New England Ropes for both anchor and dock lines. The following is from NE Ropes site:"Three Strand RopeWhen selecting 3-strand rope look for the following characteristics: Rope should be firm but flexible -- a firm rope resists chafe, snagging and wear, and also prevents hockling or kinking. Test the rope by flexing it a bit. It should require effort to open the lay of the rope for inserting the first tuck of a splice. The effort is light for a small size such as 1/4" and great for 5/8" or 3/4". If it opens easily, it's too soft, and will not last. The 3-strands should lay smoothly and uniformly within the rope so they all work together and wear evenly. Sight down a length. If it appears slightly "wavy" and uneven, there is a high or low strand and the rope is "out of lay." Don't buy it. Nylon and Polyester (Dacron) fibers are very fine (smaller than a human hair) and, therefore, fragile. Consequently, they should be laid into a rope with sufficient twist in the yarns and strands to form a round, firm, balanced structure that resists snagging and wear. Push your thumbnail into the strand. It should not be soft and punky. The rope should be heat stabilized to precondition the rope and keep shrinking and hardening to a minimum."The $175 may or may not be a good deal. There is some poor quality stuff on the market.I would only buy from a known source.
