I have a 150 genoa
with blue Sunbrella and a 120 with Dacron. While the Sunbrella is heavier and more expensive, it seems to be holding up a bit better than the sail with the Dacron (although that sail gets far less use). While some complain that the Sunbrella is heavy and will negatively impact light air performance, I have never really noticed that happening. I think having light air sheets may be more important. I am also curious about the headsail sock mentioned by Rick below. While I think it may be a good alternative, if you have a spare headsail halyard, I would have some doubts about how well those plastic zippers will hold up to UVs over time. If the zipper deteriorates, like most eventually do, you have to replace a really loooooooong zipper. Everything about boats is a tradeoff...
