E
Ed Fluss
I wondered if anyone had a good checklist for spring cleanup and launch. Especially engine/shaft/prop checks for a Yanmar 2GM FWCI guess the standard list begins with:-Bottom check for blisters,chips,etc-Bottom sanding-Bottom paint-Add zinces ---where?-Check all thruhulls & lube them if not done for winter-Battery Charged and Check to hold charge-Check alternator and batt charger-Check all filters, fuel(2),oil -Check all fluids,fuel,oil,antifreeze->add stablizers?-Check stuffing box (lubricate if dripless)-Check shaft coupling bolts-Check and lube throttle cable (both ends)-Check and lube Stop cable (both ends)-Check bildge pump(s) and float switche(s)-Check Water lines (wet the boat)So what did I miss?Thanks
