sulpher smell
A
alans
hi when, we opened boat i put about 3 oz. of bleach in holding tank. would that creat a sulpher like smell upon flushing. if so im sure the cure will be pump out. any suggestions? thanks alan
Dec 2, 1997
9,011
- - LIttle Rock
Yes, it would Bleach has no place on a boat...
And especially not in the toilet or holding tank. Urine has high concentration of ammonia...ammonia and chlorine create a toxic gas that can even be lethal. Never use any household bowl cleaners, bleach or products that contain bleach, Lysol, pine oil cleaners, or any other household chemical cleaning products in a marine sanitation system. They're highly damaging to rubber and hoses. Pump out and thoroughly rinse out your tank...then use only products made for marine toilets and tanks. To learn how to maintain your system, you might want to check out the link below.
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
Similar smell, different place . . .
We get a sulfurous smell from our fresh water tank; espicially the hot water. Do you think that is from the chemicals in the water after sitting a while or is a re-commissioning in order? It seems as though if the water system needed flushing+chlorine+flush+vinegar+flush, I'd get something different like a musty/moldy/rotten egg kinda smell.
7,752
Alden 50 Sarasota, Florida
Clark
to state the obvious, if it's noticeably different with the hot water, you're either volatilizing fumes because of the temperature or it is the interior of the water heater - easiest way to tell is shut off the heater element and allow cold water to run through the heater. If you can eliminate the heater, it's simply a matter of recommissioning the piping and tank(s) with a dilute chlorine solution with sufficient residence time to allow the chlorine solution to work. If you don't first eliminate the water heater, no amount of chlorine will have an effect.
Dec 2, 1997
9,011
- - LIttle Rock
Sulphur smell in hot water only...cold water is ok
Water heaters 101: Anodes are included in the water heater of glass-lined steel tanks to protect the inside of the tank against corrosion from acids in the water, stray electrical currents, etc. Glass lined tanks, when the water heater is being built, are heated up red hot. Then glass powder is sprayed inside the tank and it adheres upon contact. However, it doesn't cover every single crack and crevice inside the tank - it should, but in actual practice, it doesn't. The purpose of the anode is to protect those spots inside the tank that have not been glass-covered from rusting away prematurely. The anode is eaten away, rather than the tank being eaten away. Kind of a backup to the glass lining. The anode is a magnesium rod, about 3/4" in diameter that is attached to the inside of the hot water "out" nipple, via a plastic coupling. It is electrically isolated from the fittings and from the tank. It extends all the way across the inside of the tank, stopping just short of the other side. There is an iron rod in the center of the magnesium that supports it, the iron being stronger than the magnesium. As the magnesium is eaten away and the iron rod exposed, there's a chemical reaction between the water, the iron and the magnesium that causes the "rotten egg" smell. Replacing the anode and flushing out the tank will usually make the foul smell go away. Now for the bad news. Not all water heaters have glass lined tanks...the inexpensive ones have anodized aluminum tanks instead of a replaceable anode. When the anodizing has been eaten through, the only cure for the "rotten egg" smell in the hot water is a new water heater. If both the cold and hot water taste and smell funky, that can be cured by recommissioning the system, which should be done annually as part of spring recommissioning. I just posted directions for doing that last week, so you should be able to find 'em fairly easily.
A
alans
thanks peggy and clark, i emptied tank and smell is gone. peggy, your link to maintainance is blank.i sure woul be interested in that there are so many products for sale and ever manuf. claims they work.the only smell we get is when we open sette. it is a sharp chemical smell. not horrible but not fresh. when we close seat up it is not noticable... thanks alan
Dec 2, 1997
9,011
- - LIttle Rock
My guess...
Your description of an odor that has a sharp chemical quality to it sounds like Your sanitation hoses have begun to permeate with odor. It would be most noticeable in the settee where the tank is because the tank discharge hose is most likely to permeate first. It'll get worse as the weather gets hotter...and the only cure for permeated hoses is new hoses. So I suspect you should plan on replacing 'em next fall. Meanwhile you can slow it down by flushing plenty of clean fresh water down the toilet before the boat will sit, and also rinsing out the tank and discharge hose after every pumpout. The link that brings up a blank page SHOULD take you to my book in the online chandlery here. I'll let 'em know it's quit working.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Thanks Peggy
I think you explained my situation with my stinky hot water heater. I had originally thought the antifreeze had maybe had a bad reaction in the heater. I'll check it this week to see if it has an anode. Manny
