suitable relay for glow plug circuit M 25
rmwac
Apr 22, 2011
19
Catalina 30 Watkins Glen
I have C 30 # 3619 with an M 25 diesel. I would like to use a relay to eliminate the glow plug power having to run to the cockpit panel, so I am working with heavier gauge wire, no trailer wire plugs. I have done the panel/wiring harness upgrade from Cat Direct. I am looking for a marine-suitable relay to use in this circuit. Thanks in advance.
3,983
A standard ford starter soleniod would work great... you can also get them in a 100amp constant duty model for a few more dollars... or the evviromentally sealed units.... but any auto parts store will have the ford starter relay/solenoid
Jan 6, 2010
1,520
Guys,
I need some Education here. Do I assume the relay is to save battery power not having the glo plugs energized when also cranking, thus saving draw?
CR
Feb 6, 1998
11,722
Guys,
CR
No, the relay is simply to tap into the heavy gauge wiring so the small gauge run, that draws 45+/- amps, (in-rush is higher) does not need to carry the current all the way to the panel and then back to the glow plugs via small wire..
I use a Cole-Hersee (often the 24059) heavy duty/constant duty solenoids for this as I find they last longer than the no-name intermittent duty versions from an auto parts store...
Buy Cole-Hersee Solenoids At Sailboatowners.com
mortyd
Dec 11, 2004
952
Catalina 30 easy living
pardon the ignorance of this hard-starting m25 owner, but what does the solenoid do and where does it go, both electrically and physically?
morty, you might want to read the link I provided, and the wiring diagram in the OP's post. They explain it pretty well.
"Hard starting" rarely has anything to do with glow plugs (unless they're not getting warm, that is) and is usually related to poor electrical connections, whether the trailer plugs or the main engine ground connection.
Engines 101 - One of the better collections of M25 Series Universal Engine Information on the Internet, plus some M35, too :)
http://www.c34.org/wiki/index.php?title=Diesel_Engine
May 7, 2011
231
Catalina 36 1430 Lake Lanier
As Stu said below, Hard Starting has multiple potential causes. The PO of our 1985 with an M25 had the starter rebuilt, a solenoid (Starter Relay) for the starter, all kinds of 'fixes' done by a 'Professional Mechanic' that did not solve the issue. Once I replaced the OEM cable and plugs we've never had an issue since. Be sure to read this link for other things to be aware of: http://c34.org/bbs/index.php/topic,5078.0.html
Jan 28, 2017
76
Catalina 30 Mk II Yorktown, VA
Just wanted to say that I recently completed the modification to the glow plug circuit on my Catalina 30/M25. Boat starts much more easily. Many thanks to all who contributed.
