My 2 cents
Marcia,Lexan is the stronger choice and virtually unbreakable However, it is also much softer, i.e. it will scratch way more easily. Unless your hatches will be taking big waves in direct hits, or if you'll be consistantly dropping stuff from the masthead (or getting into gunfights?)then the extra strength won't really be needed.I don't have the strength numbers in front of me but a thick enough piece of plexi (more than 1/4"!) should do fine for 24"x24" span under normal usage.I seem to recall reading somewhere that the darkening/yellowing is about the same for either material, though plexi may start crazing sooner?I've also read that silicone is the best for seating material. It's not the strongest sealant but other caulks will yellow with UV though regular silicone, apparently even that which is behind the plexi. Also, if you have any mechanical fasteners passing through the plastic (screws, bolts) make sure that the holes are oversize to handle the shrinkage & expansion of the plastic material.cheers,CraigRanger 28
