Suggestions on trailer
4
Currently have a strains 19 on a tee new trailer that has a tilt bed and extendable tongue. The Starwood weighs around 1900 lbs. I just bout a Mac 25 that is sitting on a standard trailer with surge brakes that currently don't work. The tee new trailer is adjustable and I honk I could adjust it to fit the Mac but the Mac trailer is stouter. Should I swap trailers? Thanks for your thoughts and time, Chris.
bria46
Jan 15, 2011
286
Oday 272 Waukegan, IL, Sarasota, FL
Pictures please. Need more info to make correct evaluation.
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
A stout purpose built trailer with surge brakes that might need repair..
or a lightweight TeeNee trailer made for a lighter, smaller boat...???
I think we have enough info...
-na -NA Anywhere USA
If the issue is brakes and the brake actuator is not working, most likely culprit is the master cylinder one is made of composit and the other metal depending on brake vs. surge brakes. If the resivour is full and air is bled out, that most likely is the problem. Simplyu take the cover off and remove it and then go to a trailer parts place and order it. Cost is about $65 vs. a whole new one at about $275
