Perhaps consider a bollard with bow chocks
Alex,I don't know the Hunter 23 very well but since you seem to want to set up your bow cleats primarily for anchoring and secondarily for docking I suggest the following arrangement:(1) try to find a sturdy deck area, right in the center and just forward of the anchor locker (aft of the locker is a second choice alternative). Chances are that you may be able to create a strong triangular deck pad between the forestay and the anchor locker. Reinforce it, if necessary with some fiberglass plies. (2)then use this deck pad area to mount as big and strong a stainless steel bollard as you have room for. Equipped with a proper backing plate, this bollard effectively becomes your equivalent of the old "Samson Post" and will be the central attachment point for your dock lines, as well as your anchor rode, mooring line, towline or (heaven forbid) sea anchor rode. To use it for anchoring make sure that you have a nice captive anchor roller, preferably on a very short "bowsprit" to keep the rode clear of chafing.In order to prevent chafing from your dock lines or mooring line, find to small stainless steel "bow chocks" (fairleads with an open slit on top) and mount them on the outermost edges of the deck, far enough forward of the bollard so the lines will run at a 30-60 degree angle between bollard and chock.As far as the stern cleats go, if you ever use them for tying to a stern anchor, try to mount them in the outermost aft deck corners in order to avoid chafe damage to lines and fiberglass (or use chocks again).Fair winds.Flying DutchmanPSSanta Barbara was the homeport of "Rivendel II" from 1991 to 1995!
