Suddenly Hard starting YSM12
Rob
My YSM12 suddenly became hard to start last week. Batteries are topped off, it has fuel, cranks well, water pump works well and the exhaust elbow is 2 years old. Usually it would start on the 1st crank and suddenly last weekend I had to crank 15 times ( with the through hull closed so as not to flood the cylinder). Any ideas??? I can get it started and when it does it runs great but not easily.
Benny
Air in the fuel system.
you may have developed a pinhole leak in a fuel line.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Sounds like air
I'm with Benny. My old renault started doing the same thing a couple of weeks ago. I drained the filter thinking it may be water, then bled the lines all the way to the injector, and still had to add a little oil in the starting reservoir to get the engine to start. Once started I found that there is a leak around the injector (still trying to figure out exactly where). It is letting air into the system, causing the hard starting. Try using a clean paper towel around all fuel lines to see if you get any diesel on it. Good Luck, Manny
