I had a big scare today, was sailing on a rather windy day and looked down into the cabin and found about 18" of water over the deck area. It came in real suddenly and steadily. I had a friend with a trailer that could handle the boat and we pulled it out after a lot of pumping. long drawen out process. Waht we found was that the knot meter sending unit was broken loose and that there was about a 2 inch hole in the hull where it had been. after looking every thing over we found that the sending unit had been sealed in with what appeared to be regular pipe dope. that hole will be patched but I will be checking the rest of the through hull fittings to see if they were put in the same way.
