I recently changed the raw water pump impeller on the Yanmar 2GM20FW diesel on my 2000 Hunter 320. After restarting and warming up the engine for about 20 min I put a load on the engine and headed out and 5 minutes later the high temp alarm sounded. I also noticed alot of vibration in the cockpit floor. What could be the problem? Here's what I've checked so far: I rechecked the water pump impeller installation & confirmed the impeller turns OK and was installed in the correct direction, the new O-ring seal is working (no leaks from the pump), and tightened up the pump belt.I cleaned the intake water strainer (it wasn't clogged).I disconnected the antisiphon valve on the hose to the engine exhaust manifold & tested it & it was working properly. Started engine up again, it spit water OK, and it had the same vibration in the cockpit floor/stern area, both when running in nuetral and in gear. I didn't let the engine run long enough to see if it would overheat again. The vibration seems to be coming from the muffler area. The engine runs smoothly, and shakes only a very little bit on its mounts (mechanic said its normal), but the stern and cockpit floor sound and feel like they're rattling? Since the vibrations occur even when not in gear, I don't suspect the shaft alignment of cutless bearing. Do wet exhaust mufflers ever go bad? The exhaust outlet is at the waterline, so its hard to tell how much water is coming out, but it is splashing. The rattling is definetely something new. What else should I check? I'm stymied.
Al
Al
