3 times
3 wraps should do it - more than that and you could cause an overheating problem in the stuffing box. Since you say this is your 1st stab at this:Cut 3 separate rings of flax that completely surround the prop shaft (ie no gap in the flax joint). Do not use one continuous piece and wrap it three times. Cut the (teflon impregnated)flax on an angle so the ends join together better.Stagger the breaks in each flax piece 90 degress at least so that they do not overlap.Use a high quality teflon lubricant and rub it on each piece of flax. With teflon impregnated flax you're not supposed to need extra lube, but hey what the hec.Tighten the stuffing box hand tight until the boat is launched. Afterwards, tighten the nut until there are about 2 drips per minute comming out of the box. Make sure you put the locking pin and/or locking wire back on the nut to prevent it from turning.Note you may need to adjust the nut tightness more than once before things settle down. And from my own experinece, I find replacing the stuffing flax every 2 years is best. That flax stuff can become hard as concrete if left in long enough. Have funMike
