My stuffing box decided to start leaking (2 drips per second) while I was warming up the engine to change the oil!So I came home and studied everything in the archives about stuffing boxes and have a couple questions about my '87 Hunter 31:(The attached photo is not mine, it's just a similar stuffing box I googled)When I put a wrench on either of the two nuts on the shaft and wiggle gently, it causes the rubber boot to move also. From this I deduced that the whole stuffing box assembly is just clamped to the rubber boot with the 2 hose clamps. Correct?My stuffing box assembly is rather green.... other than spraying it with PB Blaster, is there anything else specific that I can/should do to clean it?It appears that the aft-most nut on the threaded shaft is the lock-nut and the forward nut is the compression nut that holds the packing material in place. They appear to be threaded onto the same threaded shaft. Am I correct?It between the two nuts, there is a smooth piece with a tab. Am I right in assuming that this is part of 1 of the nuts? (This might be obvious when I clean some of the corrosion).If I get the locknut loose first, how do I hold the shaft in place while working the compression nut loose? Two possibilities occur to me: either put a wrench on the threaded shaft, or back the lock nut all the way down the threaded shaft and grip that.Does anybody know the right size packing for my boat? I didn't think to measure the shaft. I suppose I'll buy both 3/16 and 5/16 packing and return the size I don't use.Am I an idiot for thinking to do this in the water on a Sunday when the boatyards are closed? I've got to believe I can keep the boat from sinking, even if I screw it all up. Also don't feel like worrying about it all week and want to sail next weekend.OK, enough random ramblings from me. Thanks in advance for the advice and wise counsel..... even from those of you who tell me I'm an idiot!!!Cheers,Bobs/v X SAIL R 8
