Dan Hutchinson
I just repacked the stuffing box on my 1986 Hunter 31'. No one told me before I started this that Hunter, at least on this model, uses washers between layers of packing. This makes it appear, when the adjustment nut is unscrewed, that there is NO packing in the gland, because a washer is in front of the first layer of packing. The only way to get at the old packing (that I could come up with) is to slide the whole stuffing box back and forth on the shaft to get the washers to pop out. This involves taking the hose clamps off the rubber boot that seals the stuffing box and the shaft tunnel. I also had to do quite a bit of "clean up" work on the shaft to get the stuffing box to slide up the shaft freely. Plus I couldn't get three layers of 5/16" packing to go back in; I had to settle for one 5/16" and two 1/4" strips. Any comments?
