Go To Website For Picture
Bob if you go to www.shaftseal.com, you will get an idea what some of the dripless seal systems look like. These do not use flax packing, but rely on a different type of seal, such as graphite, rubber, etc. to keep the water out. These are for the most part maintenance free. Some use graphite, water or oil for lubricating the spinning shaft. Practical Sailor just did a review of these systems that replace conventional stuffing box's. Sounds like you may have one. If you do not have the 2 big brass nuts between the shaft tube hose and your shaft coupling plate at the transmission there may be one of these new type of shaft seals. If your still having trouble, repost your query at the props and driveline forum on the homepage. The host of that forum is the company that sells the pss shaftseal system.Donevansdo@ene.gov.on.caevansdo@vianet.on.ca
