Tom
The stuffing box (if that's what it is called - where the prop shaft passes through the hull) has started to leak. It's moved from an occasional drip to a slight trickle. There is what looks like a big bolt where it is leaking. Is the repair as simple as tightening this bolt a little until the trickle goes back to an occasional drip?Any advice greatly appreciated.
