Hi All,
I've been looking at an Albin Vega and today I did a more
thorough 'survey'. My only negative findings (so far) have been under
the cockpit. Thank goodness there is a removable floor!
My #1 concern is the old exhaust system. The engine is a Yanmar 2GMF
that is fresh water cooled. The picture below shows it's linkage to
what appears to be the original Albin gas engine exhaust, which
consists of an outer rubber hose and an inner metal (I assume) pipe.
http://www3.telus.net/sailing/ex2.jpg
From what I can see the exhaust gasses pass through the metal pipe,
and the raw cooling water from the heat exchanger runs over the pipe,
inside the rubber tube, to exit at the other end, then each going
their separate ways to meet again at the transom exit. As you can see
in the picture below the thing has a leak. The red hose on the left
is from the cockpit drain, starboard side. The black 4 inch
corrugated hose is the bilge blower exhaust.
http://www3.telus.net/sailing/ex1.jpg
My #2 concern is the stuffing box (I think this the correct term,
after all, I am an 'outboard guy')
The two pictures below, as well as showing more of the old exhaust
system, show the stuffing box and green stains from the spinning
shaft. The drip rate is about 2 per second, and it seems to remain
constant whether the engine is in gear and reved up or just idling.
http://www3.telus.net/sailing/ex3.jpg
The white 1 1/4" plastic line is from the manual bilge pump.
http://www3.telus.net/sailing/ex4.jpg
As the broker pointed out, there's nothing there that money won't
fix. My only question was "whose money?"
Bottom line is I like the boat and am willing to fix the problems,
but I need to know #1: what's involved with fixing the stuffing box,
and #2 what expense am I faced with for parts for a new exhaust, and
what would be the best system to use?
As always, any and all opinions and advice are welcome
