Depends on the stuffing
There are different types of packing used and the type determines how tightly you want to adjust it. Some drip a drop or so a minute and some can be adjusted tight enough it doesn't drip at all. For the teflon or wax impregnated old fashioned kind, back off the locking nut (the inner one) while holding the gland nut in position. You don't want the stuffing box to turn against the rubber hose that connects it to the stern tube. When the locking nut is turned off a turn or more then tighten the gland nut 1/8 to 1/4 turn and see if the drip slows or stops. If the shaft is worn this is like chasing your tail. No matter how well you adjust it it will start leaking again before too long. Dave Doolin1969 M30 Angel's Wing
