Jerry Dykhuisen
I have one of those famous O'Day 23's with a cast iron keel. As has been noted many times, the centerboards have a tendency to get stuck up inside the keel and mine is no different. I'm asking for some hints on maybe getting it down.I already tried putting a rod through the cable hole and hitting it with a hammer. I've cleaned out the slot in the keel from underneath as far up and as best I can. I've even drilled and tapped a long lag bolt into the centerboard and tried to pull it down and/or tap it down by putting visegrips on the bolt.Any other suggestions?
