You are not alone
I agree with the reluctance to push through the hole from above.I have the earlier model, with the crank in the table post. Be sure that the pennant line/cable is actually unwound and released. I have had a couple occassions where a lunar tide packed mud into the centerboard slot, and I was able to free the board by probing the area on both sides of the board with a 1/4" rod with a hook bent into the end. I have used the saw idea when out of water to assure the interior of my cast iron keel slot is clear. But in the water, I have had more luck clearing debris out of the slot using the hooked rod. It takes some time, but usually results is a rewarding downward swing of the board when the offending mud is clear enough. There is room at the end to get a narrow strap up and over the end of the centerboard, if you think you have cleared obstructions on the sides, and you need to overcome the friction of a jammed pennant shackle or similar. Good luck.
