How picky is the Misses?
Joe, if you have a better half who insists there is only one proper way to paint the boat, you'll just have to keep scrubbing. Aesthetics are nice, but there's a point where "Let's go sailing" has to happen.CLR and some of the other "calcium and lime stain" type removers work well for iron stains too, but if the old paint was porous and something really got into it, or you just run out of elbow grease, it may be simpler to just clean it as best you can, and then paint over it. Either raise the bottom paint or add a boot stripe--because boot stripe paint is especially meant to be in that wet zone, it is more durable than the topside paint or old porous gelcoat higher up on the boat.And if you don't like to paint, check out 3M's vinyl boot stripe tapes. Exterior grade vinyl that typically lasts 5-10 years without problems, goes on just like masking tape, can hide a lot of sins.<G>
